Gå til produktinformasjon
1 av 1
AiM Taipan Motocross ECU Plug & Play
SKU: C-ECU
£480.00
£480.00
AiM Taipan ECU Plug & Play Engine Control Unit
This specific TaipanECU is unprogrammed. It can be configured for any brand or model bike you require. You will need the UC Bridge Tuner to enable this process.
Once the unprogrammed TaipanECU has been configured with a dedicated brand or model it can not be changed. You will be able to modify the maps written into the ECU but the brand or model which has been configured can not be changed.
Traction Control
Traction Control Strategy
Launch Control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the TaipanECU guarantees the precision of 1/10 of the degree: this means an accuracy within 0.8 uses for turning the spark ON!
Tuner License :
This is the Tuner that is required to configure the unprogrammed Taipan ECU.
Taipan ECU Connections
The Taipan ECU has 4 connectors :
2nd CAN Connector - Connect to the UC Bridge, to communicate with the PC.
3rd Connector - Connect to spare analogue inputs and a possible second injector.
Below shows a functional diagram of products that can be added to the Taipan ECU:
  • One low side driver (1 A)
  • Power consumption 150 mA
  • n. 1 33 pin male Connector
  • Body: PA6 + 30% glass fiber
  • Waterproof: IP67
  • Weight: 260g
  • ECU Taipan Control Unit
Traction Control
Launch Control
Tuner License :
  • Waterproof: IP67
  • Weight: 260g
Video
