AiM Steering Angle Belt
SKU: S-SA-B
- £20.00
- £20.00
Replacement steering angle belt for the Steering Angle Rotary Potentiometer/Belt type sensor.
Replacement steering angle belt | Spare or replacement parts |
The steering angle belt is a replacement or spare part for the AiM car steering angle rotary potentiometer sensor.
Use as a replacement or spare part.
One Steering Angle Belt supplied.
- Replacement Steering Angle Belt
- 1 x Replacement Steering Angle Belt
Replacement steering angle belt for the Steering Angle Rotary Potentiometer/Belt type sensor.Key Features :
The steering angle belt is a replacement or spare part for the AiM car steering angle rotary potentiometer sensor.Use as a replacement or spare part.
