Gå til produktinformasjon
1 av 6
AiM Solo 2 & Solo 2 DL Bar Pads
SKU: SOLO-PD-WB
£60.00
£60.00
Bar Pads For Solo 2 & Solo 2 DL
The AiM bar pads are designed to allow fitment of the Solo 2 & Solo 2 DL to the handlebars of a motocross bike.
Key Features:
  • Easy Installation
  • Includes transparent cover
  • Suitable for all MX motorcycles
  • Free race studio 3 download
Motocross Bar Pads
These pads have been designed to allow the fitment of an AiM Solo 2 & Solo 2 DL to the handlebars of a motocross bike.
The pads are shock-resistant and safe thanks to their polyurethane structure.
Provides secure and reliable fitment of a Solo 2 & Solo 2 DL to a motocross bike.
Able to withstand the tough forces of racing.
Versions for this item for handlebars are with or without the cross brace.
Please Note. The Solo is not included
Not Enough Check Out Our Solo 2 DL & SmartyCams
AiM Product Video
    Bar pad with a brace
    • Bar pad
    • Transparent protection cover
    • Mounting bracket
    • 4 12mm M3 screws
    • Installation guide
    • Dimensions: 220x137.5x86.8mm
    • Weight: 274g
      User Guide
      Technical sheet
      Key Features:
      • Easy Installation
      Motocross Bar Pads
      AiM Product Video
        Whats In The Box
        • Bar pad
        • Mounting bracket
        • 4 12mm M3 screws
        • Weight: 274g
          User Guide
          Technical sheet
