Gå til produktinformasjon
1 av 3
AiM Solo 2 DL RPM & External Power Lead Motorcycle
SKU: SOLO-K4-L
£42.00
£42.00
The AiM PRM cable is used for vehicles when the particular ECU is not supported.
8 pin - 712 male binder connection 3 free cables
Suitable for Solo 2 DL
RPM External Power Cable
In the unlikely event, your particular ECU is not supported you can connect the Solo 2 DL to the coil RPM which will provide a digital input delivered from square wave signals or pulse signals.
This is one of the connection cables available for the Solo 2 DL. Others are the OBDII and the RS232/CAN cables.
  • 8 pin - 712 male binder connection
  • 2m Cable
  • Red - 9-15 VDC
  • Black - GND
  • White - RPM
  • Solo 2 DL OBDII & External power cable connector
  • 2m Cable
  • Red - 9-15 VDC
  • Black - GND
  • White - RPM
