Gå til produktinformasjon
1 av 2
AiM Oil/Water Thermocouple Temperature Sensor M10 K Type Kart
SKU: S-T-M10-M-K
£70.00
£70.00
The AiM water thermocouple temperature sensor with M10 thread allows you to measure water temperature by placing the thermocouple in the cooling system.
Measure water temperature  Thermocouple male fitting
Wide temperature range 2 pin male Mignon connector
The AiM water thermocouple temperature sensor with M10 thread allows you to measure water temperature by placing the thermocouple in the cooling systemThe AiM K Type thermocouple temperature sensor is fitted with two pins male thermocouple connection.
It can measure the water temperature by being placed in the cooling system. When fitting the sensor, ensure it is far from heat and electromagnetic interference sources like the RPM cable or lap receiver cables.
Temperature range of 0-150°C
Sensor cable length 25cm
  • Temperature working range: 0-150°C
  • Cable sensor length: 25cm
  • Cable Type: Compensated
  • K Type thermocouple
  • AiM Thermocouple M10 Oil/Water Temperature Sensor
