Gå til produktinformasjon
1 av 4
AiM Oil / Fuel Pressure Sensor Dash 3 3/8 24 0-5 Bar Motorcycle
SKU: S-P-F-D3-MC
£190.00
£190.00
The AiM 3 3/8 24 0-5 Bar pressure sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 5 bars.
Dash 3 3/8 24 0-5 Bar 4 pins 719 male binder
The Dash 3 3/8 24 0-5 bar pressure sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 5 bars.
The Dash 3 3/8 24 0-5 bar pressure sensor is fitted with a male four pins 719 binder connector to suit our loggers and dash display/loggers.
This sensor is also available in an M10 0-5 Bar. Available in the accessories tab.
  • Supply: 8-16V
  • Consumption: < 10 mA
  • Sealing: IP66
  • Weight: 30g
  • Cable Length: 400mm
  • Thread: 3/8 24
  • AiM bar pressure sensor 3/8 24 0-5 Bar
  • Supply: 8-16V
  • Sealing: IP66
  • Weight: 30g
  • Thread: 3/8 24
