MyChron5 Steering Wheel Bracket
SKU: MY-SW-B
- £12.50
- £12.50
+ MVA (kun Storbritannia)
Easily mount your MyChron5 behind the steering wheel with our AiM steering wheel bracket.
Attaches the OTK steering wheel | Easy fitment |
Easily mount your MyChron5 behind the steering wheel with our steering wheel bracket.
This mounting bracket is designed to be attached to OTK steering wheels to allow the fitment of our AiM MyChron5 lap timer in accordance with MSA rules.
Designed to fit 3-hole and 6-hole steering wheels.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_Brake_Pressure_Sensor_M10_0-100_Bar_Kart_expand_your_system.png?v=1624538604)
- Attaches to OTK Steering Wheels
- 1 x MyChron5 Steering Wheel Bracket
Easily mount your MyChron5 behind the steering wheel with our AiM steering wheel bracket.Key Features :
Easily mount your MyChron5 behind the steering wheel with our steering wheel bracket.This mounting bracket is designed to be attached to OTK steering wheels to allow the fitment of our AiM MyChron5 lap timer in accordance with MSA rules.
![AiM MyChron5 Steering Wheel Bracket - AimShop.com](http://www.aimshop.com/cdn/shop/products/AimMychronSteeringWheelBracket_1445x.png?v=1593529959)
