AiM Hall Speed Pick Up Sensor 719 Plug Motocross
SKU: S-S-H719-MX
- £70.00
- £70.00
+ MVA (kun Storbritannia)
Hall effect wheel speed sensor | 719 plastic connector |
2m cable | M8 thread |
719 Connection to suit MXL (Strada and Pista), MXG/MXS/MXP (inc Strada), MXL2. Use a 719-719 Patch Lead to extend to the required length.
- 719 plug Binder Connector
- Power Supply: 10-30 VDC
- Sensibility Distance: From 0.5 to 2,5mm
- Sensor Thread: M8
- Operating Temperature Range: -25 to 70°C
- 1 x Hall Effect Speed Sensor 719 Plastic connector 2m Cable
The AiM non-contact sensor needs a metallic trigger to pass in front of it. It comes with a magnet and locknuts.Key Features :
AiM 712 Hall Speed Pick Up Sensor (2m cable). The output varies when it meets a magnetic field. The three-wire sensor produces a digital signal.The sensor consists of a thin piece of metal that passes a continuous current through it. When the sensor is placed in a magnetic field the electrons move to one side of the metal and protons move to the other side of the plate. You will then be able to get a voltage.
719 Connection to suit MXL (Strada and Pista), MXG/MXS/MXP (inc Strada), MXL2. Use a 719-719 Patch Lead to extend to the required length. ![]() |
- Sensor Thread: M8
![AiM Hall Speed Pick Up Sensor 719 Plug Motocross - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMM8HallSpeedPickup719Motorcycle_6050468f-fbfa-4f4e-a90a-87ba2ea7e752_1445x.png?v=1613639748)
![AiM Hall Speed Pick Up Sensor 719 Plug Motocross - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMM8HallSpeedPickup719Motorcycle2_49f24666-a3e1-4faa-8fa6-faab2820a036_1445x.png?v=1613639748)
