Gå til produktinformasjon
1 av 3
4 & 8 Channel Sticker Sheets for Wireless Steering Wheel Plate
SKU: RBI-SS
£20.00
£20.00
These stickers have been designed to fit our wireless Motorsport wheel plates.
Racing faster and safer every track day knowing exactly where your buttons are on your wheel plate.
Making driving more effortless you can customise your button plate exactly how you want it to be.
This kit offers an incredible amount of stickers for you to choose from . Choose your icons and text design with to suit your requirements.
Please Note: The wheel plate image above shows how your button plate could look with stickers applied. Wheel Plate not included.
Customise your Wheel plate
The stickers are pre-cut, hardwearing and professionally printed on tough vinyl with environment protection applied.
The stickers have been designed to specifically surround the buttons allowing a perfect fit on your button plate.
Two sticker sheets are supplied with this kit. The different colour options allow you to apply stickers to the more essential buttons you wish to stand out.
The stickers are waterproof and fade-resistant, so they won't peel off when they get wet.
  • 120 motorsport stickers:
  • 120 waterproof, 120 microns, vinyl stickers
  • Low initial tack with high ultimate adhesive
  • Overall sheet dimensions 310mm x 220mm
  • Circle stickers have a 12mm internal diameter hole - apply before soldering
  • Sausage stickers follow a 12mm diameter curve and can be retro-fitted where the switches are already soldered
  • Two sticker sheets for buttons for 4 & 8 channel wheel plate. 120 stickers
