Gå til produktinformasjon
1 av 4
Yamaha YZF-R1 (2009 - 2014) AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-YAM-3
£710.00
£710.00
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Yamaha YZF-R1 this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide Yamaha YZF-R1 ECU connection cable
This kit has been specifically designed for the Yamaha YZF-R1 (2009-2014). The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Yamaha ECU will give you all the engine performance information you need to help improve your driving performance.
Yamaha YZF-R1 (YEC included) - 2009-2014
The Yamaha YXF-R1 ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the Yamaha YZF-R1 plug & play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM Yamaha YZF-R1 Connection Cable
  • Bracket
  • 2 spacers
  • 2 self-locking nuts M6
  • 4 washers M6
  • 2 self-locking nuts M4
  • 2 washers M4
  • 2 Allen screws with rounded head M6 x 60mm
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
  • Bracket
  • 2 spacers
  • 4 washers M6
  • 2 washers M4
