Link Honda CIVICLink - #HC96X PlugIn ECU
SKU: HC96X
- £995.00
- £995.00
Designed for the 1996-1998 Honda B16 and B18 engine. All models that use the Honda “OBD2A” ECU.
Onboard MAP sensor not included
Suitable Applications:
ACURA: 98-99 CL & 00-01
Integra LS/GS/GS-R/Type-R
HONDA: 98-02 Accord DX/LX/EX
99-00 Civic DX/LX/EX/Si
PlugIn Key Features:
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
Volt 5 Analog 0-5V input
Volt 6 Analog 0-5V input
Aux 7 Auxiliary Output
Aux 8 Auxiliary Output
Volt 7 Analog 0-5V input
Temp 3 Temperature sensor input
Expansion connector 2
Ign 5 Ignition 5 Auxiliary Output
DI 9 Digital Input
DI 10 Digital Input
Volt 8 Analog 0-5V input
Volt 9 Analog 0-5V input
ACURA: 98-99 CL & 00-01Integra LS/GS/GS-R/Type-R
G4X PlugIn Key Features (where applicable):Up to 6D fuel and ignition mapping
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:Expansion connector 1
DI 9 Digital Input
DI 10 Digital Input
- G4X PlugIn ECU
- Stickers
