Gå til produktinformasjon
1 av 1
Link Honda CIVICLink - #HC92X PlugIn ECU
SKU: HC92X
£850.00
£850.00
Designed for the 1992-1995 Honda B16 and B18 engine. All models that use the Honda “OBD1” ECU.
No onboard MAP sensor.
Knock control is not available on this ECU.
Suitable Applications:
1992-1995 Gen 5 Honda Civic DX/LX/EX/Si
ACURA: 92-95 Integra RS/LS/GS/GS-R
HONDA: 90-95 Accord DX/LX/EX
93-95 Del Sol S/Si, 94-95 Del Sol VTEC
90-91 Prelude Si & 92-95 Prelude S/SE/Si/VTEC
Gnd Sensor Ground Only
An Volt 4 Analog 0-5V input
An Volt 5 Analog 0-5V input
An Volt 6 Analog 0-5V input
Aux 8 Auxiliary output (0.5A current MAX)
DI 6 Digital Input
G4X PluhIn Key Features (where applicable):
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
There is no separate expansion connector on the TT Link. Expansion pins are accessible through the main header, listed below.
Pin 110 - An Temp 3
Pin 111 - An Volt 10
Pin 112 - DI9
Pin 113 - Ign 6
  • G4X PlugIn ECU
  • Stickers
DI 6 Digital Input
CAN port
Staged injection
Pin 110 - An Temp 3
Pin 112 - DI9
Pin 113 - Ign 6
  • G4X PlugIn ECU
  • Stickers
