Gå til produktinformasjon
1 av 2
Black 35 Pin AMP PDM Plug Connector Housing Socket
SKU: P-AMP-35-B
£15.00
£15.00
The 35 pin AMP is a brilliant and rugged connector housing. They boast high reliability under high temperatures and even feature an IP67 rating.
35 pin AMP connector Rugged & highly reliable
The35 pin AMP plug connector is a brilliant and rugged connector housing. It boasts high reliability under high temperatures and even features an IP67 rating. The connectors have a 2-piece contact hold design with secondary locking to prevent the contact from getting tore out under harsh conditions. These connectors accept a wire size of 0.5 to 1.25mm².
Features and Benefits:
• Rugged and highly reliable design
• IP67 rating to protect against the harshest of conditions
• Housed in a strong plastic
• 2-piece contact hold
• Integrated latch for mating
• Operating temperatures of -40°C to +125°C
  • Number of contacts: 35
  • Type: Automotive connector housing
  • Gender: Female
  • Number of rows: 3
  • Current Rating: 17A
  • Mounting Type: Cable Mount
  • Colour: Black
  • Termination Method: Black
  • Height: 27.6mm
  • Width: 63.4mm
  • Depth: 33.6mm
  • Minimum Operating Temperature: -40°C
  • Maximum Operating Temperature: +125°C
  • Housing Material: PBT
  • Waterproof: IP6K9K
  • 1 x 35 Pin AMP Plug Connector
  • Gender: Female
  • Number of rows: 3
  • Colour: Black
  • Height: 27.6mm
  • Width: 63.4mm
  • Depth: 33.6mm
