Gå til produktinformasjon
1 av 2
Aprilia RSV4 RR/RF, 1100, Tuono V4 RR Factory AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: APR-PP
£67.00
£67.00
Aprilia RSV4 RR/RF, 1100, Tuono V4 RR Factory AiM Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Aprilia bikes. Allowing easy installation to a Solo 2 DL or EVO4S Data Logger. With a 7-pin 712 male binder connection.
Aprilia plug & play cable 7 pin - 712 male binder connection
The plug & play cable currently fits the following Aprilia bike models:
Aim Aprilia Motorcycle
Aprilia RSV4 RR/RF - From 2017 Aprilia RSV4 1100 - From 2019
Aprilia Tuono V4 RR/Factory - From 2017
Example data protocols
  • Below is a pinout drawing for the Aprilia plug & play connection cable
  • Aprilia RSV4 Plug & Play connection cable
