Gå til produktinformasjon
1 av 2
AiM Water/Oil Temperature Sensor PT100 M5 Thermo Resistor Motocross
SKU: S-T-M5
£70.00
£70.00
The AiM PT100 M5 Thermo resistor temperature sensor is suitable for reading water and oil temperatures.
Suitable for water/oil temperature 4 pins 719 male binder
PT100 - M5
Sensor cable length 25cm
  • Temperature working range: 0/150°C
  • Cable sensor length: 250mm
  • M5 Thermo resistor
  • 4 pins male 719 Binder connection
  • 2kΩ 1% resistor between pins 1 and 4
  • AiM Water/Oil Temperature Sensor M5 Thermo Resistor
PT100 - M5
