Gå til produktinformasjon
1 av 2
AiM PDM32 With 5" Race Icons Display GPS Data Logging Kit
SKU: PDM-32-5
£2,050.00
£2,050.00
The AiM PDM32 is a 32 channel advanced power distribution module designed to power a multitude of vehicle circuits, removing the need for traditional fuse boxes and relays. The 5" TFT display with race icons features a fully configurable display with a range of layouts to choose from and a GPS Module providing easy lap timing and lap position for track mapping.
32 RGB LEDs Eight analogue digital inputs
GPS lap timing Four digital inputs
28 High side outputs 4 Half-bridge outputs
Power Distribution Module
The PDM32 can receive data from the vehicle ECU and even includes a data logger and GPS Module for lap timing and track mapping. The GPS Module is available with cables from 50cm up to 4m. There is also a GPS roof version available in 2m or 4m.
PDM32 Power Outputs
PDM32 Inputs
PDM32 Data Management
Dash Display 5" Race Icons
5" TFT display Race Icons
Five - Status LEDs Ten - Shift light LEDs
Suitable for replacing all of the dashboard gauges and warning lamps, the TFT dash display is available in 5", 6" or 10" versions and with "Race" or "Road" icons. Both versions have full user-configurable displays and offer a range of layouts.
The display also doubles up as a reversing mirror using a separately available camera—ideal for cars with limited rear vision. You can add up to 2 cameras for both front and rear views. You can find the optional Reversing Mirror Camera in the Accessories Tab.
Optional Wiring Solutions:
  • Inputs:
  • 14 Fully Configurable, max 500 Hz each:
  • 8 analogue/digital
  • 4 digital inputs
  • 2-speed input
  • Power Outputs:
  • 4 rated up to 20 A (high power)
  • 12 rated up to 15 A (mild power)
  • 12 rated up to 10 A (low bridge)
  • 4 rated up to 35 A (half-bridge)
  • Protected for: over voltage, under voltage, over current, over temperature
  • Total max current: 120 A
  • LEDs: 32 RGB LEDs + 1 PDM ON + 1 PDM STS (Status)
  • Lin Bus: 1
  • CAN Connections: 3
  • Internal platform: 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
  • Remote Display Connection: 1 AiM stream output
  • Connectors: 2 AMP connectors + 2 Binder connectors + 1 Amphenol Surlok connector + 1 Rosenberger connector
  • Internal memory: 4 GB
  • External modules: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD, Formula Steering Wheel, Remote I/O Pushbutton Module
  • External Analogue Camera input: 2
  • Body: Anodised Aluminium
  • Dimensions: 234.5 x 94.6 x 49.5mm
  • Weight: 761g
  • PDM Dash 5" TFT Display:
  • Display: 5" TFT
  • Contrast: 600:1
  • Ambient Light Sensor: Yes
  • Status information LEDs: 5
  • Shift Light LEDs: 10
  • Body: Anodized Aluminium
  • Pushbutons: Metallic
  • Weight: 640g
  • Power Consumption: 150 mA
  • GPS Module:
  • 5 Pin Binder connection
  • Weight: 60.5g
  • Power Distribution Module PDM32
  • TFT Screen 5" Race Icons
  • GPS Module
  • x 2 35 pins AMP Connector
  • Surlock Connector
  • Rosenberger LVDS Connector
  • CAN EXP Cable
  • Download Cable
PDM32 Power Outputs
PDM32 Inputs
  • Inputs:
  • 4 digital inputs
  • 2-speed input
  • Power Outputs:
  • Lin Bus: 1
  • Weight: 761g
  • Display: 5" TFT
  • Contrast: 600:1
  • Weight: 640g
  • GPS Module:
  • Weight: 60.5g
  • GPS Module
  • Surlock Connector
  • CAN EXP Cable
  • Download Cable
