Gå til produktinformasjon
1 av 5
Aim MXm Compact Dash Display
SKU: MXm-X87MXM0000
£1,025.00
£1,025.00
"SmartyCam Options" is required
"Temperature Sensors (Patch Lead Included)" is required
"Fuel / Oil Sensors" is required
"Lambda Sensor & Data Hub" is required
A Compact GPS Dash For Motorsports
Display your data and improve your racing and track day experience with advanced data logging and data acquisition capabilities.
MXm Dash Key Features
Compact 5" Display
Range Of Data Sources
Freely Configurable Pages
High-Contrast LCD Display
Wi-Fi Connectivity
CAN & Analogue Data Input
4GB Memory
Integrated GPS
5 Configurable LED Shift Lights
2 Configurable Alarm LEDs
Why Choose The Aim MXm Data Logging Dash
The compact MXm dash display unit features advanced data logging capabilities and is designed for racers needing all the essential information to monitor the behaviour of their vehicles and to improve their performance. This dash is designed to acquire and display data from your ECU, as well as from the internal GPS receiver, analogue/digital inputs and predefined math channels.
A Wide Range of Data Sources
The MXm features 2 CAN connections for obtaining information directly from the car's ECU, with a wide range of compatible ECU systems available to choose from. The MXm offers the most straightforward method of installation whilst offering 4 analogue and 2 digital inputs for additional data input.
Two Power Outputs
The MXm features two power outputs that can drain up to 15 A each. These outputs can be configured to turn on or off depending on the value of the analogue or digital inputs. This functionality allows you to automatically control external systems, such as switching additional lights on or off or activating and deactivating cooling fans or circulation pumps when specific events happen.
Integrated Shift Lights & Alarms
The display has an integrated shift light system that features 5 fully configurable LEDs which can be customised to your requirements and for each gear. Two further LEDs can be configured to operate as warning alarms, allowing you to customise colours, alarm types (solid or flashing), flashing frequency and accompanying text messages. Alarm priorities can be set to suit your specific requirements.
Sharp Liquid Crystal Display
Making use of a sharp liquid crystal screen, you can select which information you want displayed and the backlight can be switched between 7 available colours, all with high contrast and easy to read graphics.
Data Recall On Screen
The information that is displayed on the screen can be fully configured to prioritise the most important information for the driver. If there’s too much information on the screen, the driver can scroll between multiple pages using the integrated buttons so that nothing is missed.
After the session has ended, all of the data can be recalled on the screen including a summary of the driver's best laps along with max/min RPM, speed and temperatures. If you prefer going through the data in more detail, the MXm features a Wi-Fi function to enable fast and secure data transfer to a laptop or PC up to 50 metres away, so you no longer need to take the laptop to the car.
MXm Expansion Diagram Example With Data Hub, Lambda Controller & SmartyCam
As with all our data logging systems, the Mxm is part of a modular system which allows you to get the most out of your data. When connected to the optional Aim Data Hub, the MXm dash can be used in conjunction with the LCU-One Lambda Controller and the range of SmartyCam Cameras.
With Race Studio 3, you can also analyse all data recorded by the MXm and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performance.
Compact 5" Display
Wi-Fi Connectivity
4GB Memory
Integrated GPS
Two Power Outputs
Technical Specifications
Aim MXm Data Logging Dash with GPS
  • Ambient light sensor: Yes
  • Alarm LEDs: 2 configurable RGB LEDs
  • Shift lights: 5 configurable RGB LEDs
  • CAN connections: 2
  • ECU connections: CAN, RS232 or K-Line
  • GPS: Integrated
  • ECU compatibility: + 1000 industry leading EUCs
  • External Modules: Channel Expansion, Thermocouple Expansion, Lambda Controller, SmartyCam HD
  • Analogue inputs: 4 fully configurable, max 1,000 Hz each
  • Digital inputs: 2-speed inputs, coil RPM input
  • Digital outputs: 2 high side
  • Wi-Fi connection: Yes
  • Internal memory: 4 GB
  • Body: Glass Fibre Reinforced Nylon
  • Pushbuttons: Metallic
  • Connectors: 37 pins Motorsport connector + 4 pins power connector
  • Dimensions : 137 x 88.4 x 31.9mm
  • Weight: 330g
What's In The Box
  • MXm Dash Display
  • 37 Pin standard harness
  • 4 Pin Connector Kit
  • Aim Sticker
