AiM Motocross TM Racing Solo 2 DL Plug & Play Lead
SKU: TM-MX-PP
- £67.00
- £67.00
The AiM ECU plug & play cable has been specifically designed for TM Racing bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
TM Racing plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL |
TM Racing Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the TM Racing bike. This plug & play cable can be used for the Solo 2 DL.
The plug & play cable currently fits the following TM Racing bike models:
SMX 450 F1 - From 2015 | MX 250 F1 - From 2015 |
MX 450 F1 - From 2015 | EN 250 F1 - From 2015 |
EN 450 F1 - From 2015 |
Example data protocols
- Below is a pinout drawing for the TM Racing Solo 2 DL plug & play connection cable
- TM Racing Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for TM Racing bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the TM Racing bike. This plug & play cable can be used for the Solo 2 DL.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following TM Racing bike models:SMX 450 F1 - From 2015 | MX 250 F1 - From 2015 |
Example data protocols sampled include RPM, Throttle position, Lambda value, Air temperature, Engaged gear, Battery supply Map switch and many more. Refer to the technical sheet in the Downloads Tab for an extensive protocol list.Expand Your System
