AiM MemoryKey, MXL/EVO Removable Memory Device
SKU: MEM-1
- £145.00
- £145.00
The Aim MemoryKey, MXL/EVO Removable Memory Device, allows an immediate storage of data acquired by AiM loggers (MXL and EVO4), for transfer to a PC.
With 32 Mb internal memory, MemoryKey can store data concerning many sessions
No more need to wait for data download from the logger to the PC: you just plug MemoryKey in MXL or EVO4 before the session and it will automatically store data sampled by the logger.
Once the session is over MemoryKey will immediately download data to your PC as a normal compact flash. In case you need to avoid interruptions during test or race session, just plug another MemoryKey in your logger and go on sampling data.
MemoryKey can be used in a very flexible way as you can unplug it from one vehicle logger and plug it in another, also with the engine running, without erasing or overwriting data concerning different sessions.
Each session, in fact, can be attributed to each vehicle unambiguously because MemoryKey automatically opens a session when is plugged in the logger and closes it when unplugged.
Dimensions 86x25x13.5 mm
Weight 30 g
Technical Specifications
Weight 30 g
