Gå til produktinformasjon
1 av 6
AiM 37 Pin Deutsch Harness with 2 Thermocouples MXS, MXP, MXG, MXL2, Mxm Car
SKU: H37-DT-V02573050
£375.00
£375.00
The AiM 37 pin Deutsch harness with two thermocouple connectors to connect K-Line type sensors.
Suitable for MXS, MXP, MXG, and MXL2. MXm Digital output
 37 pin harness Two thermocouple connectors
37 pin Harness with Two Thermocouple Connectors for the MX Series
The AiM 37 pins harness has been designed with two thermocouple connectors, this will enable you to connect two different thermocouple sensors to your device.
Thermocouple sensors available are Exhaust Gas Temperature Sensor, Water/Oil M5 Sensor, Water/Oil M10 Sensor, and many more depending on the application.
Digital wheel speed channel 1
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
Please Note: If you wish to add extra race data then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.
Also available is our 37 pins Deutsch harness with a thermocouple connector. These are available with one or two thermocouple connectors and will enable you to connect thermocouple sensors.
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
  • Two Thermocouple Connectors - See table in Downloads Tab
  • 37 pin Deutsch Harness with Two Thermocouple Connectors
