Gå til produktinformasjon
1 av 3
AiM ACC 2 Analogue CAN Converter
SKU: ACC-1
£250.00
£250.00
logo The compact AiM Analogue CAN Converter
ENHANCE YOUR LOGGER PERFORMANCE ACC 2 is the new compact and powerful Analogue CAN Converter that manages up to four channels at 200 Hz each. Now compatible also with the AiM Solo 2 DL.
ACC 2 - Analogue CAN Converter
  • Analogue channels: 4 fully configurable channels, 24 bit, A/D, 200 Hz each: TC (with dedicated cable), TR, 0÷5 V, 0÷12 V
  • External power:9÷15 V operational 12÷15 V fully operationa
  • Connection: CAN
  • Connectors: 2 Binder 712 fem connectors
  • Material: PA6 30% glass
  • Dimensions: 44.0 x 38.0 x 19.8 mm
  • Weight:50 g
Acc tech sheet
ACC2 Analogue CAN Converter
  • ACC2 Converter
  • CAN cable
  • 4 channels harness
  • Connection: CAN
  • Weight:50 g
Acc tech sheet
  • ACC2 Converter
  • CAN cable
