Hopp til produktinformasjon
1 av 1
Yamaha YZF-R1/R1M & YZF-R6 AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: YAM-1-B
£60.00
£60.00
The AiM Yamaha motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Yamaha bracket All necessary mounting hardware
Suitable for Solo 2 & Solo 2 DL
Aprilia Solo 2 & Solo 2 DL Bracket
The Yamaha YXF-R1/R1M & YZF-R6 bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer onto your bike.
Please Note: If you are unsure this bracket will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.
Also available is our Yamaha plug & play cable for the following bike models: (Sold Separately)
Yamaha YZF-R1 - From 2015 Yamaha YZF-R1M - From 2015
Yamaha YZF-R6 - From 2017
Example data protocols
  • Specifically designed Yamaha YZF-R1/R1M & YZF-R6 bracket for the Solo 2 and Solo 2 DL
  • 1 Bracket
  • 1 rubber dowel
  • 1 Allen screw with flat head M6
  • 1 rubber washer
  • 2 Allen screws with flat head M4 x 10
  • 1 Bracket
  • 1 rubber dowel
  • 1 rubber washer
