Yamaha YZF-R1 2009-2014 AiM Solo 2 DL & EVO4S Data Logger Plug & Play Cable
SKU: YAM-3-PP
- £67.00
- £67.00
+ MVA (kun Storbritannia)
The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Yamaha plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL & EVO4S Data Logger |
Yamaha Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Yamaha_3_YZF-R1_Bike.png?v=1620645846)
Yamaha YZF-R1 (YEC included) - 2009-2014 | |
Example data protocols
- Below is a pinout drawing for the Yamaha Solo 2 DL and EVO4S Data Logger plug & play connection cable
- Yamaha YZF-R1 Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Yamaha bike models:![](https://cdn.shopify.com/s/files/1/0214/9392/files/Yamaha_3_YZF-R1_Bike.png?v=1620645846)
These are some of the items that can be added to your bike for incrementing performance and data. ![]() |
![Yamaha YZF-R1 2009-2014 AiM Solo 2 DL & EVO4S Data Logger Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/YamahaYZF-R12009-2014AiMSolo2DL_EVO4SDataLoggerPlug_PlayCable1_1445x.png?v=1620828031)
![Yamaha YZF-R1 2009-2014 AiM Solo 2 DL & EVO4S Data Logger Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/YamahaYZF-R12009-2014AiMSolo2DL_EVO4SDataLoggerPlug_PlayCable2_1445x.png?v=1620828031)
![Yamaha YZF-R1 2009-2014 AiM Solo 2 DL & EVO4S Data Logger Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/YamahaR1_YECincluded_2009-2014Solo2DLPlug_PlayCablewith7PinMale712Connector1_1445x.png?v=1620828031)
