Hopp til produktinformasjon
1 av 2
Suzuki GSX-R 600, 750, 1000, GSX-R 1000 L7 AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: SUZ-PP-SUZ-B
£125.00
£125.00
The AiM Suzuki motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
Suzuki cable & bracket 7 pin - 712 male binder connection
Bracket suitable for Solo 2 & Solo 2 DL
Suzuki Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the Suzuki bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM Suzuki bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
Please Note: Please see below for bracket information for your bike.
GSX-R600 - 2006-2019 GSX-R750 - 2006-2019
GSX-R1000 - 2005-2019 GSX-R1300 Hayabusa Gen.2 - 2008-2016
GSX-R1000 L7 - 2017 onwards
The Solo 2 & Solo 2 DL installation brackets are available for the following bike models/years:
GSX-R600 - 2001-2019 GSX-R750 - 2001-2019
GSX-R1000 - 2001-2004 and 2009-2019
Please Note: Not all product combinations are possible. Solo 2 DL installation brackets are not available for Suzuki GSX-R 1000 from 2005-2008, or GSX-R 1300 Hayabusa.2 from 2008-2016. Please contact one of the AiM support team for further information.
Example data protocols
  • Specifically designed Suzuki Plug & play cable and bracket for the Solo 2 DL
  • Below is the pinout drawing for the Suzuki plug & play connection cable.
  • Suzuki plug & play connection cable
  • 1 bracket
  • 1 toothed washer
  • 1 rubber dowel
  • 1 bracket
  • 1 toothed washer
  • 1 rubber dowel
