Replacement Bosch LSU 4.9 Probe for Motorcycle
SKU: LCU-RS
- £125.00
- £125.00
+ MVA (kun Storbritannia)
Bosch LSU 4.9 Probe
The Bosch LSU 4.9 probe is a replacement probe.
All our LCU-One lambda controllers use a wide band Bosch 4.9 probe either for its capacity of saving the original calibration for the duration of its life.
The Bosch LSU 4.9 probe has been designed to last for more than 100,000 km on a stock car.
Unlock your potential |
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn. |
Bosch LSU 4.9 Probe
![Replacement Bosch LSU 4.9 Probe for Motorcycle - AimShop.com](http://www.aimshop.com/cdn/shop/products/LambdaSensor_0258017025_BackPerspective_Compressed_ForShop_0cfa860c-d8e1-4130-8f82-d79ec2fc61c6_1445x.png?v=1668004387)
![Replacement Bosch LSU 4.9 Probe for Motorcycle - AimShop.com](http://www.aimshop.com/cdn/shop/products/LambdaSensor_0258017025_FrontPerspective_Compressed_ForShop_f80ec83a-5a2f-44e7-b2ec-a2846656aeda_1445x.png?v=1668004388)
