Remote Button Interface Keypad - Laser Etched Inserts
SKU: KP-INS
- £5.00
- £5.00
ALL CAN KEYPADS SOLD FROM 14/06/2023 WILL USE V2 PROTOCOL
We have an extensive range of laser-etched inserts available to suit any function applications required on your keypad.
15mm laser-etched inserts | Large range available |
Durable & removable | Spares |
We offer an extensive range of 15mm laser-etched inserts designed for our Remote Interface Keypads.
The inserts are 15mm in size and laser etched to a high standard, with a vast range of available icons to choose from to fit the keypads.
Please select as many inserts as you wish and add them to your shopping basket.
Please Note: The example shown above is to show how inserts will look in a keypad.
Custom your Keypad
With a fully customizable keypad, you can choose the application that's right for you.
The inserts are also easily substituted without having to take apart the keypad.
Custom your keypad in many applications such as Lights, Boost, Heating & Fans and Parking. The list is endless.
We offer a Pro range of CAN keypads available in 4, 6, 8 and 12 variations.
Our standard keypads are available in 8 and 12 variations.
Please see the accessories tab.
- Inserts: Laser Etched
- Size: 15mm
- Laser-etched insert
- The amount depends on what is selected at checkout
Technical sheet | Race Studio 3 |
ALL CAN KEYPADS SOLD FROM 14/06/2023 WILL USE V2 PROTOCOLWe have an extensive range of laser-etched inserts available to suit any function applications required on your keypad.
We offer an extensive range of 15mm laser-etched inserts designed for our Remote Interface Keypads.The inserts are 15mm in size and laser etched to a high standard, with a vast range of available icons to choose from to fit the keypads.
Custom your Keypad
With a fully customizable keypad, you can choose the application that's right for you.The inserts are also easily substituted without having to take apart the keypad.
We offer a Pro range of CAN keypads available in 4, 6, 8 and 12 variations.Our standard keypads are available in 8 and 12 variations.
- Size: 15mm
