Hopp til produktinformasjon
1 av 3
Remote Button CAN Interface Standard Keypad
SKU: RBI-B8-ST
£265.00
£265.00
Remote Button CAN Interface Keypads
The remote button interface keypads will enable you to have your very own selected buttons at your fingertips.
Configurable channels Multicolour indicator rings
CAN bus compatible keypad LED status configurable
LED-backlit icons Vertical or horizontal mount
The AiM remote button CAN interface keypads will enable you to have your very own selected buttons at your fingertips. The keypads have been built to the highest standards for the harshest motorsport conditions. The keypad can withstand the cleaning of pressure washers and holds an IP67 rating, making them immune to water, mud, soil, sand, oil, chemicals.
The keypads are available in 8, 12
Easy to Read
The keypads feature bright LED indicators, making them easy to read in any situation. The multi-coloured LED status rings allow you to set specific colours to your requirements.
With an extensive range of laser-etched inserts available, you can customise your keypad the way that's right for you, Lights, Heating & Fans; parking, the list is endless.
Please Note:
The keypads come blank with no inserts. We have an extensive range available. See the optional extras at the top of the page. Also, the lights on the keypads are for visual effect to show you how the keypad could look.
  • Remote Button CAN Interface Keypad
Easy to Read
Please Note:
Technical Specifications
