Hopp til produktinformasjon
1 av 2
Ducati Panigale V4/V2 AiM Solo 2 DL Plug & Play Cable
SKU: DUC-PP
£67.00
£67.00
The AiM ECU plug & play cable has been specifically designed for Ducati Panigale V4/V2 bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
Ducati Panigale V4/V2 plug & play cable 7 pin - 712 male binder connection
Ducati Panigale V4/V2 Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale V4/V2 bike. This plug & play cable can be used for the Solo 2 DL.
The plug & play cable currently fits the following Ducati Panigale bike models:
Panigale V4 - From 2018 Panigale V2 - From 2020
Example data protocols
  • Below is a pinout drawing for the Ducati Panigale V4/V2 plug & play connection cable
  • Ducati Panigale V4/V2 Plug & Play connection cable
