Ducati Panigale V4/V2 AiM EVO4S Logger Plug & Play Cable
SKU: DUC-PP-EVO
- £67.00
- £67.00
Ducati Panigale V4/V2 AiM EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Ducati Panigale V4/V2 bikes. Allowing easy installation to an EVO4S Data Logger. With a 7-pin 712 male binder connection.
Ducati Panigale V4/V2 plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for EVO4S |
Ducati Panigale V4/V2 Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale V4/V2 bike. This plug & play cable can be used for the EVO4S Data Logger.
The plug & play cable currently fits the following Ducati Panigale bike models:
Panigale V4 - From 2018 | Panigale V2 - From 2020 |
Example data protocols
- Below is a pinout drawing for the Ducati Panigale V4/V2 plug & play connection cable
- Ducati Panigale V4/V2 Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Ducati Panigale V4/V2 bikes. Allowing easy installation to an EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale V4/V2 bike. This plug & play cable can be used for the EVO4S Data Logger.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Ducati Panigale bike models:Panigale V4 - From 2018 | Panigale V2 - From 2020 |
