AiM Thermocouple Patch Lead - TC Yellow to 712 3 Pin
SKU: P-712-TC-15-3
- £40.00
- £40.00
The AiM thermocouple patch/extension leads are used to extend thermocouple patch leads that connect AiM thermocouple sensors.
TC Yellow to 712 | 3 Pin |
The AiM Thermocouple patch lead is used to connect an AiM Thermocouple sensor such as an EGT (exhaust gas temperature) or a CHT (cylinder head temperature) to an AIM TC Hub or directly to a MyChron4 or MyChron5 kart lap timer/dash logger.
High quality and engineered for the rigours of motorsport
712 3 Pin metal binder plug to Thermocouple yellow
- TC Yellow to 712 Patch Lead
- 712 3 pin
- Available in 50cm to 2m lengths
- 1 x Thermocouple TC Yellow to 712 3 Pin Patch Lead
The AiM thermocouple patch/extension leads are used to extend thermocouple patch leads that connect AiM thermocouple sensors.Key Features :
The AiM Thermocouple patch lead is used to connect an AiM Thermocouple sensor such as an EGT (exhaust gas temperature) or a CHT (cylinder head temperature) to an AIM TC Hub or directly to a MyChron4 or MyChron5 kart lap timer/dash logger.High quality and engineered for the rigours of motorsport
- 712 3 pin
