AiM Thermocouple Patch Lead TC Yellow to 712 4 pin Metal Binder Plug
SKU: P-712-TC-5
- £40.00
- £40.00
The AiM thermocouple patch lead TC yellow to 712 4 pins is used to connect thermocouple sensors.
TC Yellow to 712 4 pin thermocouple | Suits TC Hub, EVO4, EVO4S |
High-quality connectors | Various lengths available |
The AiM thermocouple patch lead is used to connect an AiM thermocouple sensor such as EGT (exhaust gas temperature) or a CHT ( cylinder head temperature) to an AiM TC Hub EVO4, EVO4S data loggers.
TC Yellow to 712 4 pin thermocouple patch lead with metal Binder connector
- TC Yellow to 712 4 pin thermocouple patch lead
- 50cm
- 100cm
- 150cm
- 200cm
- 250cm
- 300cm
- 1 x TC Yellow to 712 4 pin thermocouple patch lead
The AiM thermocouple patch lead TC yellow to 712 4 pins is used to connect thermocouple sensors.Key Features :
The AiM thermocouple patch lead is used to connect an AiM thermocouple sensor such as EGT (exhaust gas temperature) or a CHT ( cylinder head temperature) to an AiM TC Hub EVO4, EVO4S data loggers.TC Yellow to 712 4 pin thermocouple patch lead with metal Binder connector
- 50cm
- 100cm
- 150cm
- 200cm
- 250cm
- 300cm
