Hopp til produktinformasjon
1 av 1
Aim Spark Plug Inductive RPM Bike Adaptor
SKU: MXL-RPM-IP
£75.00
£75.00
Spark Plug Inductive RPM Adaptor
The Aim RPM Adaptor has been designed for single cylinder 2 or 4-stroke engines.
Key Features:
  • Spark plug RPM adaptor
  • Free Race Studio 3 download
RPM Spark Plug Adaptor
The Aim spark RPM adaptor has been designed for installation on single cylinder 2 or 4-stroke engines. It is a filter that converts the RPM signal sampled by induction from the spark plug into a square wave signal.
The image below shows the signal sampled by induction on the left and the square wave signal on the right.
To install the adaptor connect the plastic clip to the spark plug and the cables as follows:
The black cable labelled GND to the device GND pin.
The red cable is labelled 9-15 VDC to a +12V output (the battery positive pole for example).
The blue cable labelled RPM to Aim device RPM input.
Our mission is to help educate you and enable you to get the most out of your Aim data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn.
    Aim Spark Plug Inductive RPM Adaptor
    The drawing below shows the adaptor correctly installed.
    Key Features:
      What's In The Box
