Hopp til produktinformasjon
1 av 2
AiM Solo Motorcycle Backing Plate
SKU: SOLO-BP-X47KPFSOLO2R0
£30.00
£30.00
AiM Solo Spare Backing Plate
The AiM spare backing plate is designed for mounting the Solo GPS Lap Timer.
Spare backing plate Suitable for Solo GPS lap timer
The AiM spare backing plate to suit the Solo enables you to mount your Solo to most flat surfaces. The Solo has two large integrated magnets on the back that hold it in place, so you can simply install or remove it with ease.
Standard original mount ideal for use as a spare
Mount onto flat surfaces
  • 1 Solo Backing Plate
  • 2 screws
  • 2 washers
  • 2 nuts
  • Solo Backing Plate
  • 2 screws
  • 2 washers
  • 2 nuts
