Aim SmartyCam HD / GP HD 2.1 CAN Bus & 3.5mm Female Jack Plug For Bike Microphone Harness
SKU: SM-EM-2-MC
- £80.00
- £80.00
+ MVA (kun Storbritannia)
Aim SmartyCam HD / GP HD 2.1 CAN Bus & Female Jack
SmartyCam CAN Bus lead allows you to connect to an onboard radio/intercom.
Key Features:
Aim SmartyCam HD / GP HD 3.5mm Jack Plug
The Aim CAN cable/harness enables you to connect this to an onboard radio or intercom system (additional cable may be required depending on your radio/intercom). |
Available in 2 or 4-metre lengths. |
Aim Technologies are committed to supplying professional engineers with quality products. Our cables and accessories are well engineered and designed for rigours Motorsport. Our racing components are amongst the best in the industry today. |
Unlock your potential |
Our mission is to help educate you and enable you to get the most out of your Aim data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn. |
Aim SmartyCam HD / GP HD 2.1 CAN Bus + Integrated 3.5 Female Jack for External Microphone Harness.
Key Features:
This CAN lead connects the SmartyCam HD / GP HD and the dash/data logger with the 3.5mm jack connection being integrated into the lead. 712 7 pins to 712 5 pin Available in 2 or 4-metre lengths. |
Technical Specifications
