AiM SmartyCam GP HD 2.2 & 3 ECU CAN & Integrated Microphone & External Power Harness
SKU: SM-ECU-IM
- £80.00
- £80.00
AiM SmartyCam 2.2 & 3 ECU CAN Harness
This power cable provides direct battery power supply to the SmartyCam 2.2.
Key Features:
Aim SmartyCam GP HD External Power Harness
The SmartyCam GP HD 2.2 & 3 ECU CAN, power and external microphone cable has Motorsport engineered grade cable and fittings so it is able to withstand the harshness of Motorsport. The power cable is a useful accessory for when you want the reassurance of having the camera powered from your vehicles 12v system. |
Provides direct battery power supply to an AiM SmartyCam 2.2 camera Featuring a CAN high and CAN low connection inputs for the ECU Please Note: This connection cable is not required if you are connecting the SmartyCam to a logger or dash as power will be supplied to the camera through the CAN connection. |
AiM Technologies are committed to supplying professional engineers quality products. Our cables and accessories are well engineered and designed for rigours Motorsport. Our racing components are amongst the best in the industry today. |
Unlock your potential |
Key Features:
