AiM SmartyCam GP HD 2.1 + 2.2 External Power Harness Bike
SKU: SM-EXP-MC
- £40.00
- £40.00
+ MVA (kun Storbritannia)
AiM SmartyCam GP HD 2.1 & 2.2 External Power Harness
The AiM SmartyCam GP HD 2.1 & 2.2 external power harness can be used to be connected to an external battery.
Suitable for SmartyCam GP HD 2.1 & 2.2 | External power cable 12V |
712 - 7 pins connector | Two free wires |
The power lead fits the SmartyCam and the two un-terminated free wires will connect to a 12V battery.
The cable length is 2m.
- SmartyCam GP HD 2.1 & 2.2 External Power Harness
- Allows external battery connection 12V
- 712 - 7 pin male connection
- Cable length: 2m
- 1 x SmartyCam GP HD 2.1 & 2.2 External Power Harness
The AiM SmartyCam GP HD 2.1 & 2.2 external power harness can be used to be connected to an external battery.Key Features :
The AiM SmartyCam GP HD 2.1 & 2.2 external power harness can be used to be connected to an external battery.The power lead fits the SmartyCam and the two un-terminated free wires will connect to a 12V battery.
- Cable length: 2m
![AiM SmartyCam GP HD 2.1 + 2.2 External Power Harness Bike - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMSmartyCamGPHD2.1_2.2ExternalPowerHarness2m9_73f703de-b36e-4693-b68c-612708ee90af_1445x.png?v=1611592881)
![AiM SmartyCam GP HD 2.1 + 2.2 External Power Harness Bike - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMSmartyCamGPHD2.1_2.2ExternalPowerHarness2m2_1eb9711a-4298-47ac-99a5-c70a801ab370_1445x.png?v=1611592881)
![AiM SmartyCam GP HD 2.1 + 2.2 External Power Harness Bike - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMSmartyCamGPHD2.1_2.2ExternalPowerHarness2m3_69b6f6ff-2af3-4bb1-bfbe-3170e7306c28_1445x.png?v=1611592881)
