AiM PDM08 Pre Assigned 3m Black Connection Harness
SKU: PDM-L-08
- £225.00
- £225.00
AiM PDM Pre Assigned 3m, Black Connection Harness
The AiM wiring harness is a pre-assigned harness made from high-quality professional cables suitable for the AiM PDM08 advanced power distribution module data logger kits.
Suitable for PDM08 | Colour coded & tagged cables |
Provides easy installation |
The AiM wiring harness is a pre-assigned harness made from high-quality professional cables suitable for the AiM PDM08 advanced power distribution module data logger kits. Each of the wires on the harness is colour coded and tagged to help provide an easy installation.
Suitable for the PDM08
3 metres in length
Pre-wired connector for the easiest of installations
- AiM PDM pre-assigned 3m, Black Connection Harness
- PDM Pre-assigned Black Connector Harness
The AiM wiring harness is a pre-assigned harness made from high-quality professional cables suitable for the AiM PDM08 advanced power distribution module data logger kits.Key Features :
The AiM wiring harness is a pre-assigned harness made from high-quality professional cables suitable for the AiM PDM08 advanced power distribution module data logger kits. Each of the wires on the harness is colour coded and tagged to help provide an easy installation.Suitable for the PDM08
3 metres in length
