Hopp til produktinformasjon
1 av 5
Aim MXS 1.3 Strada TFT Car Dash Display with Race Icons
SKU: MXS-S-OBDII-XA3MXSST12A020
£1,000.00
£1,000.00
A Compact Colour TFT Digital Display with Race Icons
The MXS 1.3 Strada with Race Icons is one of the most widely used dash displays on tracks around the world due to its ability to show data coming from the ECU. Its compact size, paired with race icons, makes the MXS 1.3 Strada a go-to choice for compact motorsport setups.
MXS 1.3 Strada Key Features
5" compact TFT display
6 alarm RGB LEDs
10 shift light RGB LEDs
8 analogue inputs
CAN output
Configure data
Why Choose The Aim MXS 1.3 Strada 5" TFT Dash Display with Race Icons
The MXS 1.3 Strada has a 5" colour TFT display that offers a great visual impact. You can configure the dash to show all the information coming from the ECU, analogue /digital inputs, predefined math channels and an optional GPS Module.
The MXS 1.3 Strada is available with a choice of connection. Choose either the OBDII or K-Line CAN, depending on whether you want to connect to the car's ECU or OBDII port or directly to the ECU through the CAN channel.
Connecting the MXS 1.3 Strada dash to your ECU is simple. You can sample and display dozens of channels straight from the car's ECU. This is usually the quickest and easiest setup, needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors. The sampled data depends on the actual ECU, but will typically include RPM, throttle position, (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, lambda value (air/fuel ratio). The list of available ECU drivers is 1000+ and is constantly being updated and upgraded.
Digital Outputs
With CAN output you can send messages directly to an existing  CAN network to improve the range of vehicle control possibilities.
Digital Display
The MXS 1.3 Strada has a 5" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor which keeps the backlight at the best brightness levels.
Pre-Configured Pages
Flexible Shift Light & Alarms
The ten multi-coloured RGB shift lights can be customised to your liking, defining the RPM threshold on analogue or digital inputs, ECU values, expansion values, math channels or optional GPS option. You can choose the conditions and colours, select a solid arm or flashing one, also the flashing frequency. You can also configure an accompanying text message and set the alarm priorities.
Camera Inputs
Two analogue camera inputs are available to switch your display into a mirror camera through a pushbutton command or event management. The camera is sold seperatley.
Pin Harness
The MXS 1.3 Strada has a choice of ECU connection. Choose between the OBDII or K-Line CAN. Depending on whether you want to connect to the car's ECU using the OBDII port or directly to the ECU through the CAN channel.
MXS 1.3 Strada Connection Example With SmartyCam, Lambda Controller, Channel Expansion and GPS Module
These are only some of the items that can be added to our MXS 1.3 Strada to increment performance and the data acquired.
With Race Studio 3, you can also analyse all data recorded by MXS Strada and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
6 alarm RGB LEDs
8 analogue inputs
CAN output
Configure data
Digital Outputs
Digital Display
Camera Inputs
Pin Harness
Aim MXS 1.3 Strada TFT Dash Display with Race Icons
  • Display: 5" TFT
  • CAN Connections: 2
  • Second CAN: Yes
  • Body: Anodized Aluminium
  • Pushbuttons: Metallic
  • Power Consumption: 400 mA
  • Weight: 480g
What's In The Box
  • MXS Strada 1.2
  • 14 Pin Standard Wiring
  • Aim Sticker
