Hopp til produktinformasjon
1 av 5
AiM MXP 1.3 Strada 6" TFT Dash Display with Race Icons
SKU: MXP-S-CAN
£1,075.00
£1,075.00
AiM MXP Strada 6" TFT Dash Display with Race Icons
The MXP Strada features a 6" wide colour dash display offering great visual impact, and configurable to show data coming from your vehicles ECU.
CAN output Configure data
The MXP Strada features a 6" wide colour TFT display, offering a great visual impact. It is configurable to show data coming from the ECU, 9 axis inertial platform (accelerometer, GYRO and magnetometer). Eight analogue inputs, 6 digital inputs, pre-defined math channels, a second CAN and an optional GPS Module.
The MXP Strada is available with a choice of connection. Choose either the OBDII or K-Line CAN, depending on whether you want to connect to the vehicles ECU or OBDII port or directly to the ECU through the CAN channel.
Connecting the MXP Strada dash to your ECU is simple. You can sample and display dozens of channels straight from the vehicles ECU. This is usually the quickest and easiest setup, needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors. The sampled data depends on the actual ECU, but will typically include RPM, throttle position, (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, lambda value (air/fuel ratio). The list of available ECU drivers is 1000+ and is constantly being updated and upgraded.
Digital Outputs
The MXP features two digital outputs. The two digital outputs (Dout) are LOW SIDE type (switch to ground). They can be configured in order to be turned on/off depending on the value of the analogue or digital inputs. They permit to automatically run external systems. For example, switch on/off additional lights, to activate/deactivate a cooling fan or circulation pumps when a certain event happens.
The MXP has a 6" high contrast TFT display. The visual quality is kept optimised by the ambient light sensor which keeps he backlight to its best brightness levels, so to avoid the screen dazzling you while driving in the dark.
Pre-configured Pages
Flexible Shift Light & Alarms
Camera Inputs
Pin Harness
The MXP Strada has a choice of ECU connection. Choose between the OBDII or K-Line CAN. Depending on whether you want to connect to the vehicles ECU using the OBDII port or directly to the ECU through the CAN channel.
With Race Studio 3 you can also analyse all data recorded by MXP Strada and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
Digital Outputs
Camera Inputs
Pin Harness
  • Display: 6" TFT
  • CAN Connections: 3
  • Second CAN: Yes
  • Body: Anodized Aluminium
  • Pushbuttons: Metallic
  • Power Consumption: 400 mA
  • Weight: 590g
  • MXP Strada
  • 14 Pin Standard Wiring
