Hopp til produktinformasjon
1 av 4
AiM MX Strada Logger - kit options available
SKU: MX-TL-B-X08MMD020SL-MC
£730.00
£730.00
Strada Logger
The AiM Memory Module is a small SD Card holder connected via CAN bus to the MXL2, MXG, MXP, MXS dashes and the EVO4S and EVO5 modules. It is straightforward to use. Just simply click the Module to your logger, and You will save the data simultaneously both in the logger and on the SD card with no configuration needed.
The SD card can be removed and replaced even during pit stops while the car engine is still on, making it extremely fast to get the data during races or long tests when the time at the paddock is minimal.
When the session is over, all you need to do is remove the SD card from the Module and put it into your PC and download the data using Race Studio 3.
Please Note: SD Cards are not included in the kit.
  • Strada Logger
  • Max power consumption: 50 mA
  • Cable length: 40cm
  • SD Card: It supports up to 32GB (not included)
  • Dimensions: 55.5 x 78.3 x 18mm
  • Weight: 103g
  • Strada Logger
  • Your choice of optional extras
Strada Logger
Technical Specifications
  • Strada Logger
  • Weight: 103g
  • Strada Logger
