AiM Motocross Microtec M206 & M222 ECU Solo 2 DL Plug & Play Lead
SKU: MIC-MX-PP
- £67.00
- £67.00
AiM Motocross Microtec ECU Solo 2 DL Plug & Play Lead
The AiM ECU plug & play cable has been specifically designed for dirt bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
Microtec plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL |
Microtec Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for dirt bikes. This plug & play cable can be used for the Solo 2 DL.
Suppered models are:
Microtec M222 ECU | Microtec M206 ECU |
Example data protocols
AAiM Motocross Microtec ECU Solo 2 DL Plug & Play Lead
- Below is a pinout drawing for the Microtec Solo 2 DL plug & play connection cable
- Microtec Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for dirt bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for dirt bikes. This plug & play cable can be used for the Solo 2 DL.The cable is an easy fitment to your bike and allows ECU data to be logged.
Suppered models are:Microtec M222 ECU | Microtec M206 ECU |
Example data protocols sampled include RPM, Throttle position, Lambda value, Air temperature, Engaged gear, Battery supply Map switch and many more. Refer to the technical sheet in the Downloads Tab for an extensive protocol list.Expand Your System
