AiM Motocross Bar Pad without Cross Brace for Solo 2, Solo 2 DL
SKU: SOLO2-PD-WB
- £84.00
- £84.00
The AiM motocross bar pad without cross brace allows fitment to the handlebars of a motocross bike.
Easy installation | Includes transparent protection cover |
Suitable for Solo 2 & Solo 2 DL | Suitable for all MX motorcycles |
Motocross Bar Pad
The AiM Motocross bar pad without cross brace has been designed to mount the Solo 2 and Solo 2 DL GPS Lap Timer to any MX Motorcycle. The pad provides shock protection for the unit so they remain reliable during the harsh environments of racing.
Provides secure and reliable fitment of the Solo 2 & Solo 2 DL GPS Lap Timers.
Able to withstand the harsh environments of racing.
Please Note: The Solo 2 DL is not included, the image is to show what the bar pad will look like when fitted with a GPS Lap Timer.
- Bar pad without cross brace
- See Technical sheet in Downloads Tab
- 1 Bar pad without cross brace
- 1 Transparent protection cover
- Mounting bracket
- 4 x 12mm M3 screws
The AiM motocross bar pad without cross brace allows fitment to the handlebars of a motocross bike.Key Features :
Motocross Bar Pad
The AiM Motocross bar pad without cross brace has been designed to mount the Solo 2 and Solo 2 DL GPS Lap Timer to any MX Motorcycle. The pad provides shock protection for the unit so they remain reliable during the harsh environments of racing.Provides secure and reliable fitment of the Solo 2 & Solo 2 DL GPS Lap Timers.
- Mounting bracket
