AiM Magnetic Speed Sensor 719 Plug 1m Cable Motorcycle
SKU: S-S-M719-MC
- £70.00
- £70.00
The AiM non-contact sensor needs a metallic trigger to pass in front of it. It comes with a magnet and the locknuts.
Magnetic wheel speed sensor | 719 plastic connector |
1m cable |
The AiM non-contact sensor needs a metallic trigger to pass in front of it. It comes with a magnet and the locknuts required and are available in two versions: a plastic connector (Binder 719) and a metallic connector (Binder 712).
The Magnetic Wheel Speed Sensor can be mounted using a bracket (not supplied) and to sense a trigger magnet (included) as it rotates past. Suitable mounting positions may consist of the wheel, wheel hub, prop shaft or brake disc.
The sensor consists of a thin piece of metal that passes a continuous current through it. When the sensor is placed in a magnetic field, the electrons move to one side of the metal, and protons move to the other side of the plate. Then you will be able to get a voltage.
The sensor only produces around seven volts. When the electrons move to one side, a potential difference is created between the two sides of the metal.
The 719 connection will suit MXL (Strada), MXG, MXS, MXP (inc Strada). Use with a 719-719 patch lead to extend to the required length.
- 719 Plastic Binder Connector
- Ensure the distance between the sensor and the magnet is between 8 and 20mm
- 1 x Magnetic Speed Sensor 719 Plastic connector 1m Cable
The AiM non-contact sensor needs a metallic trigger to pass in front of it. It comes with a magnet and the locknuts.Key Features :
1m cable |
The AiM non-contact sensor needs a metallic trigger to pass in front of it. It comes with a magnet and the locknuts required and are available in two versions: a plastic connector (Binder 719) and a metallic connector (Binder 712).The Magnetic Wheel Speed Sensor can be mounted using a bracket (not supplied) and to sense a trigger magnet (included) as it rotates past. Suitable mounting positions may consist of the wheel, wheel hub, prop shaft or brake disc.
The 719 connection will suit MXL (Strada), MXG, MXS, MXP (inc Strada). Use with a 719-719 patch lead to extend to the required length.Technical
