Hopp til produktinformasjon
1 av 2
AiM LCU-One Lambda Controller Replacement Weld on Bung
SKU: LCU-FR
£10.00
£10.00
The AiM steel LCU-One Lambda Controller replacement weld-on bung.
Replacement weld-on bung Steel Bung
The AiM weld-in bungs create a permanent, easy mount for your sensor fittings.
The female-threaded steel connectors feature a natural finish.
The weld-in bungs are beneficial for retrofitting and testing applications.
Optional Extras
The Bosch LSU 4.9 Probe designed to measure the proportion of oxygen in exhaust gases. Available in the Accessories Tab.
The female-threaded steel connectors feature a natural finish. The weld-in bungs are beneficial for retrofitting and testing applications.
Optional Extras
  • Weld-on Bung
  • 24.7mm (1.5mm)
  • x 1 Weld on Bung 24.7mm (1.5mm)
