OTK Kart Pedal Position Bracket Kit 4 Pieces
SKU: B-NC-OTK-K
- £70.00
- £70.00
The kart pedal position bracket kit includes all four metal brackets and is specifically designed and engineered to convert existing kart pedal sensors.
Suits AiM throttle position sensor kit | Specific OTK karts |
Four-piece kit | |
This kit comes with a Brake position magnet holder, a Throttle position sensor bracket, a Throttle position magnet holder and a Brake position sensor bracket.
- Suits AiM Throttle Position Sensor Kit
- Suitable for OTK Karts
- Fout piece kit
- 1 x OTK Brake Position Sensor Bracket
- 1 x OTK Brake Position Magnet Holder
- 1 x OTK Throttle Position Sensor Bracket
- 1 x OTK Throttle Position Magnet Holder
The kart pedal position bracket kit includes all four metal brackets and is specifically designed and engineered to convert existing kart pedal sensors.Key Features :
Four-piece kit | |
- Fout piece kit
