Hopp til produktinformasjon
1 av 2
AiM Infrared Tyre Temperature Sensor Motorcycle
SKU: S-T-IR-MC
£95.00
£95.00
The AiM Infrared (IR) tyre temperature sensors have four pins black 719 binder plug connections to fit all AiM loggers and dash display/loggers.
IR Temperature sensor 719 binder connection
Compact IR sensor allows for contact-free tyre temperature measurements at a distance from 30 to 150 mm. An ideal bike set-up would be three sensors per tyre (inside, centre and outside). However, 1 per tyre can also be helpful if budget or channel input constraints dictate this. The temperature range is 0–150ºC with a cable length of 25 cm.
Ensure to place the sensor far from strong heat sources like the exhaust pipe and electromagnetic interference.
Connection
MXS / MXP / MXG / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display/logger and the analogue sensor, please use the 719-719 patch lead, which is available in various lengths from 0.5 - 3 metres. For most installations, you will need one of these leads.
EVO4 / EVO4S logger / Channel Expansion are fitted with 712 connections and require a 712-719 patch lead to connect these sensors.
  • Output Signal: 0-5V
  • Field of measure: 35°
  • Working range: -20/120°C
  • Sensor electrical range: 820 Mv/-20°C, 3230Mv/120°C
  • Sensor dimensions: 26.6 x 17.2mm
  • IP rating: IP65
  • Sensor cable length: 250mm
  • x 1 IR Tyre Temperature Sensor
Connection
  • IP rating: IP65
