Hopp til produktinformasjon
1 av 3
AiM Hall Speed Pick Up Sensor 719 Plug 2m Cable
SKU: S-S-H719
£70.00
£70.00
"Patch Lead Type" is required
"Patch Lead Length" is required
Hall effect wheel speed sensor 719 plastic connector
2m cable M8 thread
719 Connection to suit MXL (Strada and Pista), MXG/MXS/MXP (inc Strada), MXL2. Use a 719-719 Patch Lead to extend to the required length.
2m cable M8 thread
The sensor consists of a thin piece of metal that passes a continuous current through it. When the sensor is placed in a magnetic field the electrons move to one side of the metal and protons move to the other side of the plate. You will then be able to get a voltage. The Hall Effect Sensor is a non-contact device that needs a metallic trigger to pass in front of it. Again, a bracket will usually need to be fabricated to mount the sensor in a suitable position. Please ensure that the distance between the sensor and trigger is in a 0.5 – 2.0 mm (0.007-0.07 inches) range.
  • 719 plug Binder Connector
  • Power Supply: 10-30 VDC
  • Sensor Thread: M8
  • Waterproof: IP67
  • 1 x Hall Effect Speed Sensor 719 Plastic connector 2m Cable
