Hopp til produktinformasjon
1 av 2
AiM Hall Speed Pick Up Sensor 712 Plug 2m Cable
SKU: S-S-H712
£70.00
£70.00
Hall effect wheel speed sensor 712 metal connector
2m cable M8 thread
  • 712 Metal Binder Connector
  • Power Supply: 10-30 VDC
  • Sensor Thread: M8
  • Waterproof: IP67
  • 1 x Hall Effect Speed Sensor 712 Metal connector 2m Cable
2m cable M8 thread
  • Sensor Thread: M8
  • Waterproof: IP67
