Hopp til produktinformasjon
1 av 2
AiM 719 (Plastic) Binder Plug Female
SKU: P-719-F
£10.00
£10.00
The AiM 719 binder plug 4 pin female is ideal for replacing damaged plugs or for when adding additional sensors or extension cables to your AiM system.
Suitable for AiM sensors 4 pin female plastic Binder
Ideal for adding to your system
The AiM 719 binder plug 4 pin female is ideal for replacing damaged plugs or for when adding additional sensors or extension cables to your AiM system. The plug has four pins.
Ideal for replacing broken plugs or when adding sensors to your AiM system
Fits AiM 719 cables and sensors
  • 719 Plastic Binder Plug
  • 1 x 719 Plastic Binder Plug Female
