AiM 712-719 Male to Female 4 Pin Patch Lead Car
SKU: P-712-719-5-V02PCB05BTXG
- £40.00
- £40.00
Use this patch lead to connect your EVO4/EVO4S logger or Channel Expansion device to various analogue sensors.
712-719 patch lead | 4 pin male to female |
Extends wiring harness | Various lengths available |
The AiM 712-719 male to female four pin patch lead extends the original wiring harness, e.g. when fitting analogue sensors. Available in different lengths to suit your application.
Use this patch lead to connect your EVO4/EVO4S logger or Channel Expansion device to various analogue sensors. You can also extend the cable length further by using a 719-719 patch lead.
- 712-719 4 pins Male to Female Patch Lead
- 50cm
- 100cm
- 150cm
- 200cm
- 250cm
- 300cm
- 350cm
- 400cm
- 1 x 712-719 Male to Female 4 Pin Patch Lead
Use this patch lead to connect your EVO4/EVO4S logger or Channel Expansion device to various analogue sensors.Key Features :
The AiM 712-719 male to female four pin patch lead extends the original wiring harness, e.g. when fitting analogue sensors. Available in different lengths to suit your application.Use this patch lead to connect your EVO4/EVO4S logger or Channel Expansion device to various analogue sensors. You can also extend the cable length further by using a 719-719 patch lead.
- 50cm
- 100cm
- 150cm
- 200cm
- 250cm
- 300cm
- 350cm
- 400cm
